Commodore A 2d Limo "breitbau"
Commodåren
Re: Commodore A 2d Limo "breitbau"
Beitrag von Commodåren » 22.03.2015, 20:40
Here is the new universal joint:
It is from a Toyota Hi Ace or Hi Lux, but there is a minor difference to the original Commodore joint, it is 1mm narrower. The Commodore joint has 29mm cups and is 79mm wide vs 29 x 78 for the Toyota part. The solution is to use 0,5mm x 29mm washers in the cup ends to make the joint even with the yoke, and secure the washers to the yoke by welding small dabs at 12, 3, 6 and 9 o'clock around the washers. :)
Beitrag von kanne » 22.03.2015, 20:59
great :idea:
but what is a washer :?:
please make a pic from that thing
best regards
Beitrag von Jörg » 22.03.2015, 21:00
Unterlegscheibe, Du Nase.
Commodåren
Beitrag von Commodåren » 22.03.2015, 21:17
kanne hat geschrieben:great :idea:
best regards
The washer is needed to centre the joint in the yoke, and since the Toyota part is 1mm narrower, it is easy to eve it up with a 0,5mm washer in both ends. It is important that the joint is thoroughly centered so there will not be any vibrations. Another thing is that the original clips from the Commodore does not fit anymore, so the joint must be fastened by welding dabs instead. Like here, except that there is no washer in the picture:
http://www.therangerstation.com/Magazin ... edcap1.gif :)
Commodåren
Beitrag von Commodåren » 24.03.2015, 14:38
Drive shaft rebuild completed.
Now it only needs to be thrown under the car. :)
Commodåren
Beitrag von Commodåren » 26.03.2015, 16:50
Today the drive shaft was bolted in place, and so were the carbs:
The hard part comes next, the building of a well functioning linkage. :)
CH GS/E QP
Beitrag von CH GS/E QP » 26.03.2015, 17:45
this certainly is a great picture of an impressive piece of machinery :icon_daumen_01
liebe Grüsse aus der Zentralschweiz
David
Commodore A GS/E Coupé kardinalrot made in Biel by GM Suisse, EZ 1.3.1971
Beitrag von the Brain » 26.03.2015, 19:18
Your coolant temperature sender doesn´t work with your Display because both work with different resistors.
Nice work, keep on going.
coralreef
Beitrag von coralreef » 26.03.2015, 19:36
Is that an oil cooler outlet on top of the oil filter ?
Antworten wie im Deutschen - ich verstehe die meisten :)
Commodåren
Beitrag von Commodåren » 26.03.2015, 22:57
@ CH GS/E QP
Thank you, yes, Weber carbs are always nice too look at. :)
@ the Brain
I've never thought about the temperature sender, thank you for reminding. I guess there are other things too that I must deal with, because the engine(and the whole car, as a matter of fact) is built with parts from several different donor engines(and cars).
@ coralreef
Yes , it's an original oilcooler adapter flange with a built in thermostat. It came with the C30NE shortblock, so I thought I could as well use it since it was already there. Perhaps I should put the cooler on the outside, like on the race Commodores ? :)
Commodåren
Beitrag von Commodåren » 31.03.2015, 18:49
At last we have a linkage, now it only needs a proper throttle return spring. :)
Beitrag von the Brain » 31.03.2015, 21:32
Commodåren hat geschrieben: @ the Brain
It´s the same Game with the Fuel sender. But thats nearly all. The rest doesn´t matters. We call it
Tankgeber( Kraftstoffmessgerät)
Ohm Werte:
Bis: Leer 0-5 Ohm Voll 25-35 Ohm ( Yours is an "BIS" Unit on this Place
Ab : Leer 250 Ohm Voll 25 Ohm
fearless-NL
Beitrag von fearless-NL » 31.03.2015, 22:58
Kudo's on your linkage for the carbs. I like it a lot!
Looks much better than a cable.
I want this on my triple trottlebody setup on the future, so i saved your picture :D
Rekord C Sedan -> c30ne :mrgreen:
Shine can never replace attitude!
Commodåren
Beitrag von Commodåren » 09.04.2015, 10:56
fearless-NL hat geschrieben:Kudo's on your linkage for the carbs. I like it a lot!
Thanks, I was pleased too with how the linkage turned out in the end.
Commodåren
Beitrag von Commodåren » 09.04.2015, 11:05
Brake caliper rebuild was on the agenda, and as we split the calipers it turned out that one of the spacers was cracked. Fortunately I had a spare Senator A1 caliper which donated one of its spacers and we were in business again. The whole brake system with front and rear calipers, HBZ, pressure regulator, BKV and brake discs comes from a Commodore B/GSE. The only thing left before assembly on the car is to have a pair of brake hoses made, as the original B GS/E hoses are about 15cm too short.
Wer ist online?
Mitglieder in diesem Forum: 0 Mitglieder und 2 Gäste
