Rekord C Coupe 67
Re: Rekord C Coupe 67
The four wie talked about, also a mercury switch and at least a wiper motor.
xpbernardo
Beitrag von xpbernardo »
the Brain hat geschrieben: 14.02.2024, 17:29 The four wie talked about, also a mercury switch and at least a wiper motor.
Awesome. Let me check the wiper motor on Friday
Rekord 1900 Luxe Coupé 67
Check also if you got the socket for the ashtray lamp on the right side of it.
xpbernardo
OK! Wiper motor started working. Overhauled the switch and things came back to life :D
No light socket on ashtray, but light on the glovebox and trunk would be nice: in the trunk I have the open close switch mounted but no light assy
Mercury switch on the hood light is also dead.
Open close switch and light assy is one piece. You have a picture for me?
xpbernardo
Didn´t get the chance but it´s exactly like the one in the picture.
Remember our conversation about the MIXO horns and the relay? Manage to find on schematics of a relay just like mine. It´s for a 6V but dor the matter that doesn´t make any difference. The connections are exactly the same. Did everything like the picture but when I give ignition to the car the horns stay on . Without ignition the horns beeps when I press the steering whell buttons and the battery light blinks and the TEMP pointer kicks :?: :mrgreen:
If I give direct + and - to the horns thay work perfectly...
Strike! Let the horns smoke...
That's not what I meant, the ashtray insert is always the same. It's about the holder on the passenger side.
Under the red insulating tape is the screw and the second picture shows the opening for the lamp socket. This is the back . There is a dent in the sheet metal with a hole where the holder is screwed on.
This is the entire lighting system. You can see the holder that is still present on your Z-igniter.
xpbernardo
I have the yellow one ( lighter) . Don´t have the red ones ( ashtray and glovebox) or the harness with the bulbs.
I have the trunk switch but not the bulb
Trunk lighting from VIN. But check again where the hole for it is in your vehicle. It's a round hole on the left near the rubber bumper.
xpbernardo
Yes I have that to install after all in the trunk. The manual states a different part but I have that one
You need one or you have one?
The manuell shows the first Version i suppose. The output maybe earlier than your Unit.
xpbernardo
The trunk I have just like the one in your picture.
Don't have the glove box and the bulbs harness.
The mercury switch on the hood is also dead
nordfisch
Beitrag von nordfisch »
xpbernardo hat geschrieben: 18.02.2024, 11:32 ...
The problem is the original horn is switched by ground <earth> and this one is switched by positive current.
IF your relais has exactly the schematic you show us, you could just interchange the wires '1' and '3' and all would be fine.
Regards
Norbert
xpbernardo
nordfisch hat geschrieben: 19.02.2024, 11:55
Regards
Norbert
Already solved. There was an earth cable badly connected. The one that connects the engine block to the body. Once cleaned and retorqued and horns started behaving normally 👍
xpbernardo
So......
Testing rim came with ET20. Everything perfect.
No touching in the front. Still looking original without the wheels coming to far out. Manage to give a little more depth to the rim.
5 going to final painting with to tone grey and black. Also chrome rings should arrive next week.
Meanwhile...Solex completly overhauled with new kit and cleaning and fitted
