Rekord C Coupe 67
Re: Rekord C Coupe 67
Möglich, Kernlochdurchmesser Carsten?
Ich frage mich einfach wozu?
Check.
- xpbernardo
Work almost done and heading for painting
Spare wheel with fiber patch and a hole . Already like new again
Rekord 1900 Luxe Coupé 67
- xpbernardo
Also Instrument cluster rechromed. Now for the finishing decoration
6,44 ist keine mir bekannte Größe fürs Innenloch beim Opel. Übrigens nutzt man die Innenschenkel zum messen.....
Spaß, ist aus meiner Sicht niemals original. Wozu auch in einer Rekord Wanderdüne.
@ Looks Great Man!
@ Looks Great Man!
welding work completed ? looks greatxpbernardo hat geschrieben: ↑28.03.2023, 21:23 Work almost done and heading for painting
- xpbernardo
Help guys. This clutch linkage shaft looks a bit bented... It's suppose to be straight? This angle looks wrong... Wanted to make it correct before engine is out in place...
The rechroming looks very well!!! How did you proceed?xpbernardo hat geschrieben: ↑28.03.2023, 21:27 Also Instrument cluster rechromed. Now for the finishing decoration
Having a look back to 2012/13 we can see the same geometry as on your car. I don't know, if this is correct, but it works on my car...xpbernardo hat geschrieben: ↑29.03.2023, 12:30 Help guys. This clutch linkage shaft looks a bit bented... It's suppose to be straight? This angle looks wrong... Wanted to make it correct before engine is out in place...
- xpbernardo
Was made by a rechrome company here in Portugal. 150€ plus VATOlli457 hat geschrieben: ↑29.03.2023, 15:09The rechroming looks very well!!! How did you proceed?xpbernardo hat geschrieben: ↑28.03.2023, 21:27 Also Instrument cluster rechromed. Now for the finishing decoration
- xpbernardo
Olli457 hat geschrieben: ↑29.03.2023, 15:19Having a look back to 2012/13 we can see the same geometry as on your car. I don't know, if this is correct, but it works on my car...xpbernardo hat geschrieben: ↑29.03.2023, 12:30 Help guys. This clutch linkage shaft looks a bit bented... It's suppose to be straight? This angle looks wrong... Wanted to make it correct before engine is out in place...
Awesome. Looks exactly the same! It's good then..
Thanks!
xpbernardo hat geschrieben: ↑29.03.2023, 16:01Olli457 hat geschrieben: ↑29.03.2023, 15:19Having a look back to 2012/13 we can see the same geometry as on your car. I don't know, if this is correct, but it works on my car...xpbernardo hat geschrieben: ↑29.03.2023, 12:30 Help guys. This clutch linkage shaft looks a bit bented... It's suppose to be straight? This angle looks wrong... Wanted to make it correct before engine is out in place...
Thanks!
If I remember correct, its the anglepoint of the leverarm of the park break in the under dashboard variant.
Sehe gleich mal nach ob ich ein Bild finde.
Ansonsten mache ich morgen mal eins.
