Die Hollander mit dem Caravan und Sedan
- fearless-NL
Hallo an alle, mein Deutsch ist nicht gut, damit ich sprechen Englisch.
I am Dennie and i live in The Netherlands,
These are my Sedan and Caravan.
I got al my work on this site, but it is in dutch.
http://opel-forum.nl/viewtopic.php?f=27&t=127729
The sedan is a long time project, my caravan is a daily drive.
My Sedan
It needed a lot of welding and a lot of new sheetmetal.
I'm still working on it, but it's very time consuming.
This car is getting a 6 cylinder engine, C30NE with a Getrag 240.
Discbrakes on the rear using bmw discs...
I am looking for a good solution for the front brakes.
i will be using a Senator B brakebooster
I don't want to change to a 5 stud axles, i want to use the 4x100 axles.
Msw 15 inch rims, 195 50 15 tires.
My Daily caravan
it has a 2.2 cih engine with a 4 speed aw71 automatic getriebe
it only runs on LPG, no more petrol.
It has 2 seats, and the LPG tank is behind the front seats so i have a big booth for my tools and stuff. Most of the time it is empty
I have loads of pic on here http://opel-forum.nl/viewtopic.php?f=27&t=127729
but i wont post all.
I am hoping to see some good tips and nice stuff for sale on this forum.
My Sedan
My Daily caravan
Zuletzt geändert von fearless-NL am 07.12.2014, 22:03, insgesamt 1-mal geändert.
Rekord C Sedan -> c30ne
Shine can never replace attitude!
Re: Die Hollander mit dem Caravan und Sedan
Hi,fearless-NL hat geschrieben:
Waar hoort het chassisnummer te staan? ik kan hem zo snel nie vinden..
the number should be in the middle of the air guide plate.Maybe somebodey has changed the complete front without replacement of the chassis-number.
Where do you come from the netherlands ? I'm living next to the border of Venlo & Roermond.....
- fearless-NL
I copied some text from the dutch opel forum, my topic is there...i found the number allready, it's above the radiator.buckrodgers61 hat geschrieben:Hi,fearless-NL hat geschrieben:
I live in Wapenveld, near Zwolle.. The border isn't very far from here.
- fearless-NL
In holland we call those things "bumperrosetten" i don't know if they are original.
It could be a custom job....just like the headlights.
I just ordered a new radiator for it, an alloy one for a Skyline. Just have to make it fit the car
Latest picture of the sedan
The front was a bit rotten, so i welded it and made the thing a bit more stiffer.
Nice Projekt.
Keep it running.
Just for me one question, may can i get the Numbers of the Adrema Code Plate, the white Plate on your Front. And also the FIN. I´m interested because i wonder where this Unit was built, Rüsselsheim or Antwerpen.
@ Jörg, könnte sein das du das vergessen hast aber Chris hat an El Commodore auch solche Zierstücke. Könnte was mit Export zu tun haben, aber so genau weiß ich das nicht. Gibt auch welche die so ähnlich aussehen für Kadett B.
Keep it running.
Jörg, es gab sowas im Zubehör damals(als ich noch jung war). Mein Vater hatte fast genau solche "Hörnchen" an seinem Prinz 4 und es war kein "L"...Jörg hat geschrieben:Wo sind denn die seltsamen Stoßstangenhörnchen her?
Die hab ich noch nirgends gesehen.
Sachen gibts, die selbst uns "Alte" zum Erstaunen bringen...
- fearless-NL
I will make you a picture of that plate. I would like to know it too.the Brain hat geschrieben:Nice Projekt.
Keep it running.
The car is originaly dutch, no import.
It had the old handbrake under the dash...and pop-out windows in the rear and front.
Today i got my new alloy radiator, thing is huge! And thick!
