Rekord C Coupe 67
Re: Rekord C Coupe 67
Looks fine Tom. Smaler Engine also there. Bigger Engine sometimes use other Hose holder.
- xpbernardo
Rekord 1900 Luxe Coupé 67
- xpbernardo
Finally on the floor again.
Just some electrical tweaks, water hoses and small bits and pieces and the one year journey is coming to an end
Not to Bad for only one year Man.
I must admit, the Cosmics on your silver machine kinda grow on me... Nice job, really!
- xpbernardo
- xpbernardo
Final bits and bolts
Got stuck with the instrument panel warning light
One of the contacts was connected to Fuse 7. But the other one was loose, so I don´t know where to connect it...
Normally the red Lamp is for the Handbrake
- xpbernardo
As for what I remember when the car drove, it was indeed for the handbrake. However one wire was connected on fuse7 and the other one just hanging on nothing...
The original Switch ist on the Top aus the Handbrake lever
- xpbernardo
- xpbernardo
Hi
Cosmic wheels are going out Kadett wheels are going in. Waiting for them to refurbish, change ET and mount.
Now strugling with one problem. In the instrument panel everything works. All lights work, radio, air, lighter, etc. EXCEPT the back light, in the instrument panel, roof light, engine bay light. Think I bypassed the dimmer correctly but no luck
So nice Car, i love it.
- xpbernardo
Thanks. Do you know why those lights don't work? I think they all belong to the same circuit. Even if the dimmer is dead, the other lights like the interior light should be working with a door open, for example.?..
