Rekord C Coupe 67
Nash Taran
Re: Rekord C Coupe 67
Beitrag von Nash Taran »
The bottom one is for the steering column covers. You put the covers over the column, hold them together at the bottom end and put the clip on.
I think the top ones are for the heater ducts for the windscreen under the dashboard.
There is also a black Ring for the Steering column cover on the Steering Side. And after the Clamp there is a KneePad for covering.
The both clamps are for the Windshield ventilation. And there is no other Place to use. The clamp in the Middle i don´t know.
xpbernardo
Beitrag von xpbernardo »
Nash Taran hat geschrieben: 12.01.2024, 20:22 I think the top ones are for the heater ducts for the windscreen under the dashboard.
Yes they are similar but the ones for the heater ducts are thinner and are already in place so these ones have to be for another place...
Rekord 1900 Luxe Coupé 67
xpbernardo hat geschrieben: 12.01.2024, 21:49
More or less 0,8mm thick? Length ca. 133mm.
There is no other Place in the Car for these Clamps.
xpbernardo
They should be 4 then.. Only 2 are mounted..
xpbernardo hat geschrieben: 13.01.2024, 05:41 They should be 4 then.. Only 2 are mounted..
The Picture is only for Example. Its from my privat Stock that i call "Schatulle" here at home....... :mrgreen:
You need two of them, not four.
xpbernardo
But I've 2 already mounted... 🤔
xpbernardo
Engine in place
Do you recommend any clutch kit in particular? Unfortunately the rear crank seal was in pretty bad condition and clutch disk was soaked in oil. Already some wear so new one is needed. I was trying to find the SACHS kit but no luck.
xpbernardo
Manage to find an original clutch kit in an old car parts store 10 ninute from home! :D
So... Engine, new clutch and gearbox in place :o
xpbernardo
Any ideas about opcional airfilter boxes?
Mine has the closed box version. But I would like something that allow the air filter to be replaced.... I saw that there is some other versions with oval Solex fitting that has replaceable air filter. But would like to know if there are other alternatives
xpbernardo
Anybody knows where the second piece like this one is mounted?
I Have two. The one in the picture is already in place but the other one I don´t know from where it is. Support for a hose, but which one and where...?
xpbernardo hat geschrieben: 19.01.2024, 22:29 Anybody knows where the second piece like this one is mounted?
You mean this one ?
https://www.ebay.de/itm/125713217433?va ... 82b44d7776
xpbernardo
re681 hat geschrieben: 19.01.2024, 22:41
You mean this one ?
exactly. Can´t say now if the one I have has that 90 degree bend or just flat like the other one
xpbernardo hat geschrieben: 19.01.2024, 23:11
You mean this one ?
how is the hose attached to the valve cover in the rear part?
1,9 S with Solex DIDTA
