well..in that case I have 2 of them with the same height and higer than the other 2 ...the Brain hat geschrieben: ↑07.01.2024, 11:09Nope. There is no difference between left and right Side. Front an rear are different.xpbernardo hat geschrieben: ↑07.01.2024, 09:52 Just to double check... Left springs are longer front and rear right? To compensate drivers weight.
I repainted the 2 pairs and marked them, but just to make sure.....
Rekord C Coupe 67
- xpbernardo
Re: Rekord C Coupe 67
Rekord 1900 Luxe Coupé 67
Wire thickness of the front springs Rekord C 12.5mm.
At the rear, the springs vary between 12.5mm and 14.3mm.
And the diameter of the springs is different. About 5mm.
So the upper rubber only fits into the axle beam at the front and only on the front springs. There is no rubber at the bottom front. The rear has a rubber at the top and bottom. When removed, the front springs should be longer than the rear ones. This is usually because they have to bear more weight and compress more when installed.
They should also have one more coil than the rear ones.
- xpbernardo
In that case I´ve the pairs mixed up. Good thing I checked before install. So I´ll join the 2 longer ones to the front and the other 2 that are smaller in the back.
Once again. THANK YOU again the Brain
No Prob.
Test the rubbers. The front ones usually have the smaller diameter. Maybe the rears are longer for special use like AHK or more load.
From the Factory they are marked with colour.
- xpbernardo
Now you´re talking about the rubbers. Not the springs, right?
Both Man. A rear Spring is too big to fix in the axle with the correct rubber.
- xpbernardo
OK. Perhaps something went wrong in translation
So.. Front coils are longer but narrower than rear ones
Hätt ich doch besser in der Schule aufgepasst.
Übersetzen ist auch nervig
Aber wir helfen gerne
Gruß Carsten
- xpbernardo
.... ....was ist an Copy-Paste nervig.....das ist ne Sache, die in Sekunden erledigt ist......
Ja,hast ja rechtbuckrodgers61 hat geschrieben: ↑08.01.2024, 15:41.... ....was ist an Copy-Paste nervig.....das ist ne Sache, die in Sekunden erledigt ist......
Gruß Carsten
…und wieder was helernt….Schule hört nie auf…opel68 hat geschrieben: ↑08.01.2024, 19:03Ja,hast ja rechtbuckrodgers61 hat geschrieben: ↑08.01.2024, 15:41.... ....was ist an Copy-Paste nervig.....das ist ne Sache, die in Sekunden erledigt ist......
Mit Copy Paste schreiben viele ihre Doktorarbeiten und werden später Bundespräsident. So kann das enden.
Oha,dann verkauft Buck sein Rekord und sitz in der S Klasse hinten
Gruß Carsten
ihr habt irgendwie komische Gedanken....
