Rekord C Coupe 67
- xpbernardo
Re: Rekord C Coupe 67
Thats not what i meant. The Engine compartment looks very used.
When the Fender are removed its possible to see more.
Remove the front seats, the back seat and the carpet. Please take some photos that can be use!
That's the only way we can help you!
- xpbernardo
rear foot wells are MINT. Only front ones need replacing. Do you know an alternative contact to OTR? All mails are returned. I need to order the front foot wells from them..
Rekord 1900 Luxe Coupé 67
- xpbernardo
Can you tell me how do I remove door and rear panels?
Metal looks pretty solid
- xpbernardo
More pics
There is some filler but we do not understand the need for it because the metal is straight and undamaged.
Schon mal nicht schlecht und soviel Spachtel muss sowieso runter.
Aber... sieht dir vorher mal den Unterboden an.
Schweller, A-Säule von oben bis unten, Lampentöpfe, überachsbögen hinten, Bananen, Endspitzen.
- xpbernardo
Don't have photos from the bottom but it's all OK. Rocker panels in perfect condición. Only place that needs a small patch is inside the front wheel wells where it meats the body. Front floor panels on the way. Very small metal work will be needed.
I'm strugling on the inside door and rear panels removal. Can't see where is the C clip on the window regulators and where to make the rear panels come loose
Die Seitenverkleidungen hinten sind geschraubt. Im Bereich wo die bauchig ist um den B-Säulenstumpf zu verstärken sind zwei kleine Kreuzschlitzschrauben drin. Dazu musst das Plastezeugs leicht abheben, dann siehste die.
Sieht erstmal alles besser als erwartet aus, aber warum da soviel Presto drauf ist?
For the front panels, you must first remove the door handle and the crank for the window.
The side trim is fixed with clips that you only have to lever out carefully.
As Metto has already described, the rear trim is fixed with two cross-head screws that you can find under the leatherette trim. The leatherette is also attached to the frame under the plastic strip. You just have to pull it off.
- xpbernardo
The car is being completely disassembled to metal work and painting...the Brain hat geschrieben: ↑03.02.2023, 15:17 Die Seitenverkleidungen hinten sind geschraubt. Im Bereich wo die bauchig ist um den B-Säulenstumpf zu verstärken sind zwei kleine Kreuzschlitzschrauben drin. Dazu musst das Plastezeugs leicht abheben, dann siehste die.
Checking it out did the trick!xpbernardo hat geschrieben: ↑03.02.2023, 13:47 Don't have photos from the bottom but it's all OK. Rocker panels in perfect condición. Only place that needs a small patch is inside the front wheel wells where it meats the body. Front floor panels on the way. Very small metal work will be needed.
Positive surprise!
How good that you haven't ordered any floor pans yet!
Do you have the door and side panels off? could take pics...
- xpbernardo
Positive surprise!
[/quote]
I did order the front floor pans. Those are rusted out because the heater matrix is shot and dripping... Other than that the car looks mint
Positive surprise!
[/quote]
Please show us the rusted out floor.xpbernardo hat geschrieben: ↑04.02.2023, 19:26
- xpbernardo
We can pass through the other side with a screwdriver. Some areas we can poke it with a fingersable hat geschrieben: ↑04.02.2023, 20:15Please show us the rusted out floor.xpbernardo hat geschrieben: ↑04.02.2023, 19:26
