Wheel arch trim holder
- xpbernardo
Very disappointed with the wheel arch trim holders that are sold.
Spent almost 60€ and they are complete rubbish.
Pourly fabricated. Round screws in plastic?. On the first wheel arch in 8, 3 snapped right off without even screw the nut all the way...
Any alternatives?
Any alternatives?
Rekord 1900 Luxe Coupé 67
Re: Wheel arch trim holder
All of them sell the same Shit Man.
Nothing better than OPEL Stuff. But where to get from. Sometimes i bought damage Wheel Trims only for used Holders, 20 Years ago.......
I would drill through the plastic holder. Insert the screw with a washer from behind...
- xpbernardo
When giving torque the screw would rotate....
Zuletzt geändert von xpbernardo am 18.12.2023, 13:00, insgesamt 1-mal geändert.
Right, you're right, shit.
If you try to attach the screw with a 2 component adhesive? In the plastic part milled or filed a little, so that the adhesive has a torque arm? Nothing sensible but maybe it will still hold.
Is this really so difficult ?
I would glue in the screws and recut the thread before assembly.
- xpbernardo
The quality of the plastic won't allow that...Motorbremse hat geschrieben: ↑18.12.2023, 13:50 I would glue in the screws and recut the thread before assembly.
- dematerialisierer
I even made some by welding bolts on stainless steel sheet metal.
Its not a problem - i did so years ago
I take the orginal holder with busted stud - drilled a hole from behind and countersunk it.
then i take a brass countersunk head screw and solderd a brass washeron it to increase surface.
I glued this with epoxy. I mounted it with brass washers with rubber on top and tiny brass nuts.
It lasts - absolut no problem - the orginal holder has the advantage that there is a lip wich seperates the trim from the sheet metal...
Hi,
I have 20 pieces available. If you need them please let me know. Original Opel parts 174885
Thanks
Thanks
- dematerialisierer
dematerialisierer hat geschrieben: ↑19.12.2023, 18:40https://www.youtube.com/watch?v=R97TsVDC1BY
Sorry, I had to add that.
- xpbernardo
buckrodgers61 hat geschrieben: ↑20.12.2023, 09:07dematerialisierer hat geschrieben: ↑19.12.2023, 18:40https://www.youtube.com/watch?v=R97TsVDC1BY
